2020-03-10
12:16 AM
2023-05-24
07:21 PM
Rubia Torres
2020-03-10 08:24 AM
2020-03-10 08:29 AM
2020-03-10 09:30 AM
2020-03-11 02:16 AM
2020-03-27 04:37 PM
David wrote:David,
Another fast way is to create two morph surfaces in the same plane, one for the counter and one for the hole you need. Merge the two morphs with Union. Then using the special sub-element cursor , select the hole morph and delete it. That will make your hole. Then you can extrude the counter morph to the thickness you need. Don't forget to switch the selection cursor back to normal !
2020-03-28 06:31 AM
paultp wrote:
I have used this method in the past numerous times, but it does not seem to work with ver. 23. Did something change somewhere, or am I missing something. I have tried and tried, but cannot get it to work with 23. Any suggestions out there?
2020-04-01 10:27 PM
