How to make the structure?
Hello to everybody!
I'm new on the forum and it's my first time to post a thread. So I would be grateful if you can give me an advice or tip how to realize my project in Archicad. I want to make my project (shown on the scale model) using a metal structure (shown on the 2 images bellow the scale model), but I don't have idea how. Can someone give me advice how to start?
Thank you all!
17 Replies 17
Eduardo Rolon
There are different ways to approach the problem and you will need to explore which will give the best result.
Items you will need to read in the Help Files:
1. Mesh
2. Custom Profiles
3. Layers (Wireframe)
4. Beams
5. Morphs - Once you get the idea using Beams for the rough in then you can try using morphs to develop more detail.
I am assuming that you know AC basics like drawing, opening 3D window etc.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Eduardo Rolon
1st step is to draw in floorplan the shape with the intersections.
AC29 US/INT -> AC08
Eduardo Rolon
Then I would Magic Wand a Mesh to the perimeter of the shape
AC29 US/INT -> AC08
Eduardo Rolon
Then I would add the ridges to the mesh (using Magic Wand)
AC29 US/INT -> AC08
Eduardo Rolon
Which will give the following result in the 3D Window.
BTW change material for the mesh for the screenshots and also made the Mesh a single plane.
AC29 US/INT -> AC08
Eduardo Rolon
Then I will edit the intersection points of the mesh elevating them into their position.
AC29 US/INT -> AC08
Eduardo Rolon
with the following result
AC29 US/INT -> AC08
Eduardo Rolon
Change the Mesh layer to Wireframe, in this case it is the Layer L-Site
AC29 US/INT -> AC08
Eduardo Rolon
Using Complex Profiles create the section of the Beam.
AC29 US/INT -> AC08
