How to make this stair?
I have some trouble making this stair to have 2 ways at the top end, one turn left and make the other turn right.
I read the "help documents' and it says when making a customize stair i need to use 'create stairs using selection' button, but i couldn't figure out how that works.
6 REPLIES 6
Are you sure you want to make the stair you have drawn? Is this stair as drawn even legal in Australia? Could you draw in 2D lines what you want to create if different than this and it would be easier to give you help.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
I am afraid such a stair would send people directly to hospital.
Do you really want this?
If it is an existing stair (renovation), please tell us.
In such case, the problem is different.
Dwight
A wacked-out stair like this will defy almost any stairmaking tool.
Even in Australia where they walk on the ceiling.
You'll need to be satisfied with a series of slabs... use tilted beams for handrails.
Dwight Atkinson
Congratulations Dwight. The big 5000 posts
You are obviously a very helpful guy.
Gerald Hoffman
i think i should draw it a bit clear, sorry guys.
PS: i am a hight schoool studnet, just using archicad to do a major project for my high school certificate, therefore i have no knowledge of wheather this stair is legal in australia or not.
You could make it this way or as Dwight suggested.
Try to stick to orthogonal for treads or people will break their legs!
