We value your input!
How to merge two roofs?
Hi again I am still fighting with roofs This time I would like to know how if there in archicad are function which can merge two roofs in to one. Yes I know SEO tool, but it does not help, because it merge this two roofs only virtualy not visualy. I know about edge settings but the problem is that I am too dump to find out correct edge angel, so I think there is a small trick which I dont know Thank you for advises
Yes, the small trick is to select BOTH roofs before using the edge settings. Then you will only get a choice of vertical or mitred. (Or mitered, as we say here. 😉 )
Select either one and this should join the roofs properly.
Richard
AC26 (since AC6.0), Win10
Thank you very much A little note - it is better to select edge settings from 2d view, then there appear mitred function
