How to model a Cycling Track
BrentMatthew
Hello All!
Is there a way to model a cycling track using ArchiCAD native tools?
I would like to have a 150mm thick concrete for the track.
The issue is the straight and the curve are at different slopes (see attached image).
I tried using a complex profile but, it would not connect seamlessly.
Any suggestions?
Brent Matthew
Construction Modeler
BIMSOLL
i7-4930K Dual 3.4 GHz 32 GB RAM
NVidia Quadro K4000
SSD+HDD, Win7-64 ENG
AC25 (64-bit, latest build)
12 REPLIES 12
Erwin Edel
This looks like a job for mesh or morph tool to me.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Steve Jepson
BrentMatthew wrote:
I was asked to put the 'slope' on the curve and not have it on the 'straight section'.
I am trying it with the Mesh Tool, as I can't see an ArchiCAD tool giving me a single sweep and then allow me to lower one end to the lower 'strait section'.
Do you think it is the right way?
Morph and Slab in this model but there are better ways to do it.
The Objective add-on from Cadimage can do this pretty easily (see image). Let me know if you want more info.
Ralph Wessel BArch
Central Innovation
