How to modelling a buggy?
I cant modelling skeleton of buggy with any cirle profil. how to make it please help.
Isn't there an easy way to do this?
I try railing
I try profil manager
I try morph
https://grabcad.com/library/rock-bouncer-frame-1
9 Replies 9
I am not surprised!
Archicad is an Architectural modelling software.
Not really suited for this sort of thing.
You can tube a morph surface but you will have to start and stop every time you want to change the plane that it is to stretch along.
Plus it won't be easy to get the exact dimensions you want.
I know that,
When a profile manager adds a railing I thought I could do a 3d chamfer
Thank you.
As Barry said Archicad is an architectural modelling program, you really need to use a program like Solidworks, Autodesk Inventor, Catia, or Solid Edge to model this
Scott
I use archicad very well, and I wants to take everything. because very love archicad;)
Guru
Then you are stuck modelling each plane of your tubes as individual parts as Barry has first mentioned. You will end up spending a lot more time doing this in AC rather than importing it from a more suitable program...
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Sure, but Archicad is just not the right software to model something like this.
At least not very easily.
Wrong tool for the job, I can hit in a nail using a screwdriver but I can do it much faster and get a better result using a hammer
Steve Jepson
... but if you want to do it with ArchiCAD it is certainly not impossible. And not unreasonable either - if you ask me. The key is locating the node points. I could do it, so I am sure others could too.
I would use common weld fittings and locate them at the nodes, rotate as needed... connecting the fittings with a tube is easy. Even if you want have non-standard fittings, at least make them of some intentional angle. And of course the fittings and tube can be extracted into Interactive Schedules. Shop drawings would not be a difficult task either. Are you making a buggy or just fooling around with it for fun?
This reminds me of how I used to model pipe railings. I made/modeled a set of .gsm fittings for a pipe railing and fittings manufacture once. There are is a picture of it in this thread - https://archicad-talk.graphisoft.com/viewtopic.php?t=41754
Anyway, you just locate the fittings, and connect them with a tube. It's not really that difficult to do with ArchiCAD.
Steve Jepson
I try railing
I try morph
Just a thought, but you do know you can open that file in ArchCAD right? It will automatically be converted to a morph. From there you can cut it up/split and do about what ever you want to it.
