Wednesday
Can Archicad paint from bottom walls to ceiling?
Because I want to get a actual interior painted area for estimate the cost, which means painting from the bottom wall to the ceiling. However, in Archicad, when I choose a surface for the wall, Archicad paints the entire area on one side of the wall that exceeding the height of the ceiling.
Does anyone have any other solutions or ideas?
Thank you.
Wednesday
I'd model it with two different walls, because the junction with the slab doesn't "split" the wall automatically, therefore its building materials and surfaces will stay the same,
Noémi Balogh
Community Expert, Admin
Wednesday
Or make the walls with a complex profile
Thursday
A complex profile with a paint skin with a modifier to adjust the height.
Thursday - last edited Thursday
Or if your wall is a Composite with a finish skin, you could include an "air gap" material in your ceiling Composite that will remove the wall skin, though this will introduce a bunch of other annoyances..
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
