TechnicalSupport_REI
How to paint from bottom walls to ceiling?
Can Archicad paint from bottom walls to ceiling?
Because I want to get a actual interior painted area for estimate the cost, which means painting from the bottom wall to the ceiling. However, in Archicad, when I choose a surface for the wall, Archicad paints the entire area on one side of the wall that exceeding the height of the ceiling.
Does anyone have any other solutions or ideas?
Thank you.
TechnicalSupport of REI Software Co., Ltd.
https://www.reisoftwareth.com
Archicad 27-28 , Twinmotion
HP Victus | Window 11 | Core i7-11800H | Ram 32GB | RTX 3050 Ti Laptop
4 Replies 4
Noemi Balogh
I'd model it with two different walls, because the junction with the slab doesn't "split" the wall automatically, therefore its building materials and surfaces will stay the same,
Noémi Balogh
Staff Community Expert, Admin
cuba
Or make the walls with a complex profile
Apple M1 Max 32 GB
Latest AC
A complex profile with a paint skin with a modifier to adjust the height.
Guru
Or if your wall is a Composite with a finish skin, you could include an "air gap" material in your ceiling Composite that will remove the wall skin, though this will introduce a bunch of other annoyances..
