nedostizni wrote:
But it seems I needed to do that "Open Source View" thing.
What should I do? Rightclick on "3D Document" and then choose "Open Source View"?
Exactly.
The 3D document is just a 2D view of the 3D model - but still live and you can add dimensions that show the true size in any direction as it measures along the 3D planes.
You can get simple line images or coloured images just as you can for coloured elevations but you can't render these 3D Documents or show material textures.
Right click and "Open Source View" will open the 3D view with exactly the same viewing angle and it will also remember any marquees and cutting planes that you used to create the 3D Document.
No you can render to your heart content.
