How to show Velcro in model ?
I need to show how two components of a tent of which join together by velcro. How can I ' draw ' velcro or something that represents the Velcro i.e the texture in ArchiCAD ?
Also, what is the best way of showing contours of a material. Imagine a tent ground sheet, it has creases near the joins etc. I'm guessing a mesh with a few points elevated to created a uneven surface and then just have the mesh set to smooth ?
Thank You
3 Replies 3
Erika Epstein
N,
Years ago Frank CHin made a tent object, but I don't know how to get it to work in 13.
Does anyone else?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Velcro,
Find a good photo graph of velcro then create a meterial using that photo. Her's an answer I gave for a short intro to making your own material: http://archicad-talk.graphisoft.com/viewtopic.php?t=31110
Snap
Steve Jepson
NStocks wrote:
I need to show how two components of a tent ...Also, what is the best way of showing contours of a material....
You can make the seams using very short walls or even roofs. Roofs may have some advantage in that they will join and/or clean up in ways a wall can't. If you could show a picture of what you want to accomplish and to what level of detail you need it would be easier to make suggestions about how to model it.
You can make a Material/Texture of a canvas/tent surface the same way you would make what you need for the Velcro.
http://images.google.com/imgres?imgurl=http://files.turbosquid.com/Preview/Content_2009_07_15__08_07...
Free http://farm3.static.flickr.com/2592/3913635792_208358c50f.jpg
