2014-05-12
06:58 PM
2023-05-24
09:00 AM
Rubia Torres
2014-05-12 08:27 PM
2014-05-12 08:53 PM
Karl wrote:
The Wall End Tool:
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/user-interface-reference/too...
For whatever reason, the page above doesn't show a plan view, but it achieves what you want.
2014-05-12 09:12 PM
2014-05-12 10:19 PM
Karl wrote:
You're welcome. But, it should blend perfectly with all skins for an even wrap. Hard to guess from just a screenshot what might be keeping it from happening for you.
You could select just the wall and the end (2 items only selected) and save as a MOD (be sure to not check the box to replace the elements with a hotlink to the mod), zip that, and post it here for one of us to look at the parameters.
2014-05-12 10:58 PM
2014-05-12 10:58 PM
2014-05-12 10:59 PM
2014-05-12 11:50 PM
Karl wrote:
...and then this version of a Save Dialog appears (will look different on Windows for you... and for Mac users if the dialog is expanded)...
The key here - in order to have no affect on your file - is to NOT check the box indicated in the screenshot.
Just save the file somewhere, zip it and attach here. It'll be tiny.
2014-05-13 02:56 AM
