How to trim/split multiple walls/lines?
There is one thing that I find an annoyance when using Archicad. During the creation of my building there were times when it became necessary to "trim" or "split" walls. The operations is simple to use but has a flaw in its operation. In my case I had to TRIM many walls one after another but it became tedious when I had to click on the Trim button each and every time. It would have been much better if I could have click on the TRIM button once and then continue to trim each wall without having to click on the button each time. Cancelling the function could easily be done by right clicking and selecting cancel in the popup window. The could also be done for the "Split" command.
Regards,
11 Replies 11
Like this.
LeeJaeYoung
thank you so much
AC27 on window 11
