How would you handle this situation?(recessed loggia window)
I'm struggling currently with the detail of a window in a loggia (see the attached image). The isolation is turning correctly but is overlapping with the adjacent wall.
How would you do this so that the isolation turns correctly and there is no overlapping?
Thanks
1 REPLY 1
alemanda
Just brainstorming ...
Maybe you need some complex profile columns to put at the corners where the window starts in order to finish the insulation as you prefer.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
