2023-06-11 02:41 AM - edited 2023-06-11 03:41 AM
I cannot see the contour line when I create mesh tool , some pattern overlap the contour line
Solved! Go to Solution.
2023-06-12 04:00 AM
*Cover Fill.
Mesh Default Settings => Floor Plan & Section => Cover Fills
If you are wanting to see things behind your Mesh, and still want to be using a Cover Fill, you could set your Background Pen to Transparent (0).
If you are wanting to see your Trace just for reference, you could display it on top.
View => Trace Options => Trace on Top
Ling.
2023-06-11 05:19 PM
Just CLEAR the HATCH....NO HATCH!!!
2023-06-12 04:00 AM
*Cover Fill.
Ling.
2023-06-12 02:00 PM
2023-06-14 10:19 AM
hi guy, much appreciated your answer and help. i fix it by your way
