didi
I cannot see the contour line when I create mesh tool
I cannot see the contour line when I create mesh tool , some pattern overlap the contour line
1 Solution
Lingwisyer
Guru
*Cover Fill.
Mesh Default Settings => Floor Plan & Section => Cover Fills
If you are wanting to see things behind your Mesh, and still want to be using a Cover Fill, you could set your Background Pen to Transparent (0).
If you are wanting to see your Trace just for reference, you could display it on top.
View => Trace Options => Trace on Top
Ling.
Go to post
4 Replies 4
sayon3d
Just CLEAR the HATCH....NO HATCH!!!
Lingwisyer
Guru
*Cover Fill.
Ling.
ferroms84
didi
hi guy, much appreciated your answer and help. i fix it by your way
