LeeJaeYoung
I'm trying to get rid of this line.
What should I do?
AC27 on window 11
9 Replies 9
Guru
Are your two walls connecting correctly? If you move the door away, is it still there?
Ling.
LeeJaeYoung
It was because of the casing.
The problem is the fact that the casing doesn't have to be offset from the wall.
AC27 on window 11
LeeJaeYoung
The reason for doing this is to test when the finish and structural wall are separated like REVIT.
AC27 on window 11
LeeJaeYoung
The walls are well connected and disappear when you move the door.
This phenomenon occurred after specifying oversize 40.
AC27 on window 11
LeeJaeYoung
Can't you erase that thick line?
AC27 on window 11
Guru
You would need to look into how the oversize is drawn in GDL...
LeeJaeYoung
Do you mean that you can't get rid of that line in the normal way and you have to create a new GDL?
AC27 on window 11
Guru
I do not know what object you are using, nor do I know how said object is drawing that line and what settings maybe available to the user regarding said line...
LeeJaeYoung
The casing is an issue with oversize.
I handle the wall as send back.
Sometimes it doesn't.
AC27 on window 11
