2022-06-17 07:33 AM - edited 2022-06-17 09:46 AM
I'm trying to get rid of this line.
What should I do?
2022-06-17 07:50 AM
Are your two walls connecting correctly? If you move the door away, is it still there?
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2022-06-17 08:15 AM - edited 2022-06-17 09:45 AM
It was because of the casing.
The problem is the fact that the casing doesn't have to be offset from the wall.
2022-06-17 08:21 AM
The reason for doing this is to test when the finish and structural wall are separated like REVIT.
2022-06-20 05:19 AM
The walls are well connected and disappear when you move the door.
This phenomenon occurred after specifying oversize 40.
2022-06-21 07:20 AM
Can't you erase that thick line?
2022-06-21 08:08 AM
You would need to look into how the oversize is drawn in GDL...
2022-06-21 09:38 AM
Do you mean that you can't get rid of that line in the normal way and you have to create a new GDL?
2022-06-22 09:38 AM
I do not know what object you are using, nor do I know how said object is drawing that line and what settings maybe available to the user regarding said line...
2022-06-22 04:40 PM - edited 2022-06-22 04:45 PM
The casing is an issue with oversize.
I handle the wall as send back.
Sometimes it doesn't.
