IFC scheme
Is it possible to add a Predefined parameter in IFC scheme with values which you can aplly to all object's type and another project?
Up
Eduardo Rolon
Don't understand the question properly but to pass attributes from one file to another, and if I remember correctly it also applies to IFC parameters, use Favorites.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
If you define an IFC Property at the (IfcBuildingElement) level of the IFC hierarchy, I will be available for all building element types.
Also read the "Data Mapping" section on this page:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/interoperability/file-handli...
Also, if you want to use your modified IFC SCheme in another project, simply Export it and Import or Merge it in the other Project.
