Display malfunction of Graphisoft ID dashboard
Learn more
IFC scheme
Is it possible to add a Predefined parameter in IFC scheme with values which you can aplly to all object's type and another project?
3 Replies 3
Up
Eduardo Rolon
Don't understand the question properly but to pass attributes from one file to another, and if I remember correctly it also applies to IFC parameters, use Favorites.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
If you define an IFC Property at the (IfcBuildingElement) level of the IFC hierarchy, I will be available for all building element types.
Also read the "Data Mapping" section on this page:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/interoperability/file-handli...
Also, if you want to use your modified IFC SCheme in another project, simply Export it and Import or Merge it in the other Project.
