Importing my customized profile
I just did the hot fix for AC14 library. I had a lot of custom objects in the AC14 library, so I saved them to a flash drive, and then reloaded AC14 as was instructed in the download instructions. When I did this, it reset my profile to standard. I have saved my profiles as .XML files (default). I can add them to my library, but when I try to import them int work environment, they are "grayed out", and I can't open them. Any help would be appreciated.
10 Replies 10
In you Work Environment you can export all or part of it (i.e. just the Command and Layout Schemes section for the toolbars and menus - you can't have just the toolbars on their own.
You can then import this on to any other machine.
