In Archicad, How can I view the realtime FPS of the 3D viewport ?
William Yan
Hi guys, I am testing the 3D viewport feedback speed of my different pln files. I want to see the FPS of the 3D viewport when I orbit. Can I do that? Or using what software can I achieve this? Thanks!
AC 26 5002 CHI, Windows 10
4 REPLIES 4
Guru
FRAPs might work. I remember it showing up in the OpenGL rendered viewports of some programs that I was using during uni, though I don't remember what those were.... I have long since stopped using it as NVIDIA's GeForce and Shadowplay do everything better... If you have GeForce Experence installed, the stats overlay might work (alt + R), though I believe it will be of your entire screen rather than just the viewport.
Ling.
Thank you Ling. I tried FRAPs. But it didn't work. I am using a laptop with no videocard.😂
Guru
Oh? AC with the onboard, or is your laptop using some sort of hybrid CPU / GPU? All of the 3rd party programs that I know that can display FPS are based on the GPU output...
Archicad will not like you very much.
It really wants a separate dedicated video card.
Be sure to mention this if you have any support questions here, as that will often be the problem.
