Inclined tappered column
Roopa A
I want to create a tree type structure, so using inclined column. But I want it in a tappered inclined column. So if I convert that column to the morph the file size will be more. Is there any other method.
Please help me.
Thank you.
Roopa A S
David Maudlin
Roopa A:
Look at the Object "Cone 22". You can use this to create a tapered cone that is angled to the X/Y plane.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
FYI: In ARCHICAD 23 you will be able to create Slanted Tapered Columns.
Hmooslechner
After creating comlexest morps - you can activate it and save it as a new library-part. Then it will buildup way faster in 2d and 3D. Test it by yourself by multiplying it in huge numbers. It makes big diffrence.
But keep the original morph for further changes.
I did not test the result of this at the memory-ammount.
