‎2006-08-09
07:46 PM
‎2023-05-26
03:06 PM
Rubia Torres
‎2006-08-11 05:54 PM
‎2006-08-11 08:15 PM
‎2006-08-12 03:14 AM
Mike wrote:Thanks Mike, I use this when wanting to transfer parameters say from 1 door to another. I just never had thought about tranfering from library to library because of my library structure.
Rod, the parameter transfer is similar to what you can do in the drawing/modeling environment, but enables you to transfer parameters between different library objects in the object default settings, window default setting or any other type of library part dialog box.
This can be useful at times. I use to re-structure my libraries and re-adjust default settings to suit my needs, but found that I would miss out on some of the changes that new library parts offer as the program evolved and the time involved to do this was limiting. I a similar to you in that the default library organization leaves a lot to be desired, but some of the alternate ways to view the library have helped with this issue (find and subtype).Rarely do I use subtypes. Having spent much time years past in creating My_Library, as a carpenter would organise his toolbox so it is with my libraries. I just know where to put my hand/mouse to find what I need.
My new methodology is using groups of favorites to get me quickly to the part and settings I need.Agreed, how many have noticed the way 10 manages favourites now. Instead of all favourites being available to choose from, they are now only shown in the respective tool setting.
This of course requires screen real estate so you can always have your favorites palette open and big enough so you can quickly get at what you need.
‎2006-08-12 04:37 AM
silly wrote:Even this old bloke is happy to learn.
‎2006-08-14 10:03 PM
Mike wrote:Mike, I thought that the transfer did not "work" between AC9 and AC10 parts. Just like it did not work between the AC9 and the AC9SE Library. I thought that the AC 10 Library was based on the AC9SE.
One method is to transfer parameters between the 9 parts and the 10 parts in the object default settings dialog box. .... The procedure is to select the items that you want to "switch" to the 10 library, open the object default settings, search for the same part in the 10 library and alt/cntrl - opt/cmd click on the 10 part to transfer the parameters from the equivalent 9 part that was selected in the floor plan view. ...
‎2006-08-27 05:01 AM
Kyle wrote:Kyle you wrote to me 15th Aug. My out box still shows uncollected reply same day. In case you are not aware you need to check your private mail.
Thanks, /.......................thanks for your help, still trying to sort it all out
