SOLVED!
Installing Goodies 25
Harriette
Hi All,
I have followed the install instructions from here: https://Graphisoft.com/downloads/goodies/ac25-uki to install the 25 goodies package (build 4013) My Archicad build is 5010 and I subsequently re-ran the update as the install instructions advised. I then closed Archicad and restarted my computer, but none of the goodies add-ons appear when I open Archicad now, even with the default workprofile. Has anyone had the same problem or can offer some tips please?
Thank you
Windows 10 Desktop, Archicad 15.5010
1 ACCEPTED SOLUTION
Solution
They get put in the normal menu structure
Check design>design extras>
Here you should see accessories, 3d studio, interior wizard.
Those are the only ones I have installed at least.
2 REPLIES 2
Solution
Thank you @SenecaDesignLLC
