ā2022-06-13
03:16 PM
ā2025-01-30
04:26 PM
Molinda Prey
How should I take this?
ā2022-06-14 12:57 AM
try setting the fill orientation of the insulation material to "Fit to Skin"
ā2022-06-14 02:43 AM
This building material is set to fit to skin.
this sill height 400
sill height 350
this material
ā2022-06-14 02:55 AM
Is it because the window it tuck right up into the corner of the wall?
ā2022-06-14 07:45 AM
1. May I ask for an answer? ^^
I'm trying to drill a hole in the railing wall. - Graphisoft Community
2. May I ask for an answer? ^^
I would like to know how to make wallpaper for sch... - Graphisoft Community
ā2022-06-14 07:48 AM
I am sorry. this is section view. and wall is complex profiled wall.
ā2022-06-14 08:06 AM
OK, so if you drop the window down a little, does it look correct as in your other image?
If so all I can assume it is because the top of the window is corrupting the fill somehow because of the top being tucked into the angle.
If there is no difference then why does the other image look correct?
What is different?
It is very hard to say just looking at images.
ā2022-06-14 08:18 AM
ā2022-06-14 08:25 AM
So it seems to be the height of the window is corrupting the fill in section.
I don't know why sorry.
Questions like this are good to send to your local Archicad support people, if you has a Select Service Agreement.
ā2022-06-14 08:49 AM
I think a bug.
thank you..... ^^
