ā2023-06-07 01:54 PM
Does intersection priority not work with Staircases? (Please see the attached image)
Thanks.
Solved! Go to Solution.
ā2023-06-07 02:59 PM
1.
2.
right click on the slab
3.
slab will be selected as target, then you select stairs and click add as operator, choose option > subtraction and click execute
4.
ta-da
ā2023-06-07 02:31 PM
It doesn't, and it's annoying.
I use SEO for this.
ā2023-06-07 02:43 PM
@mija wrote:I use SEO for this.
Can you please explain how?
1.
2.
3.
4.
ta-da
ā2023-06-07 03:21 PM
Thanks for the graphical explanation š
Will try.
