Intersection Priority with Staircase & Slab
dushyant
Does intersection priority not work with Staircases? (Please see the attached image)
Thanks.
mija
right click on the slab
3.
slab will be selected as target, then you select stairs and click add as operator, choose option > subtraction and click execute
4.
 ta-da
Archicad 26, build 3001
Montenegro
4 REPLIES 4
mija
It doesn't, and it's annoying.
I use SEO for this.
Montenegro
@mija wrote:
I use SEO for this.
Can you please explain how?
mija
3.
4.
 ta-da
Montenegro
Thanks for the graphical explanation 🙂
Will try.
