dushyant
Intersection Priority with Staircase & Slab
Does intersection priority not work with Staircases? (Please see the attached image)
Thanks.
1 Solution
mija
right click on the slab
3.
slab will be selected as target, then you select stairs and click add as operator, choose option > subtraction and click execute
4.
 ta-da
Archicad 26, build 3001
Montenegro
Go to post
4 Replies 4
mija
It doesn't, and it's annoying.
I use SEO for this.
Montenegro
dushyant
@mija wrote:
I use SEO for this.
Can you please explain how?
mija
3.
4.
 ta-da
Montenegro
dushyant
Thanks for the graphical explanation 🙂
Will try.
