2017-06-22
08:19 AM
2023-05-23
04:14 PM
Rubia Torres
2017-07-04 02:30 PM
Barry wrote:Sorry to harp on about this but it's on my mind.....
You probably wouldn't want to do that with a floor slab.
But maybe you have a bench top or shelf - add a cover fill and bring to front and it will hide what ever is below - if you want to do that.
Or you could add a 50% cover fill to your floor slab and bring that to the front to help show the extent of the slab.
Most of the time the default order is perfectly fine, but there will be occasions when you want to change it.
Fills for example will always default to the background - but there are times when you will want to pull these forward.
Basically if it looks good, leave it. But you have the option to change it if you want.
2017-07-04 02:46 PM
2017-07-05 02:17 PM
benjamin_chan wrote:No, it wouldn't! Thankfully you can do this kind of trickery, sometimes it is even necessary.
Wouldn't it make more sense if ARCHICAD forbids display order manipulation ?
Unless there's something I'm missing that makes sense for a user to be able to manipulate the display order of two overlapping 3D objects in a 2D view....
2017-07-06 11:50 AM
runxel wrote:Not sure in what situation in a 2D elevation would you want to change the display order of 3D objects? (I am talking about the 3D object display order manipulation only). To your second point - yes - it is quite unpredictable....
(Elevations e.g.)
Sad thing is that it is often not predictable. (Like you hit the "down" button, nothing changes. And then suddenly it springs directly to the background.)
Erwin wrote:Hi Erwin, is there a screenshot I could see to see what you are doing. In my roof plans, I am able to do what you seem to be saying without having to resort to display order.
Floor plan is pretty much the only view that is not a true 3D projection. I find myself using drawing order (bring to front, send to back etc) the most in these views and yes this works with 3D elements. This also means you, for example, can bring to front a wall that would sit below a pitched roof, override the walls true 3D projection to a dashed line and create a 2D information that is understandable.
2017-07-07 03:02 AM
benjamin_chan wrote:But remember that Graphic Overrides is new in version 20 - was not available in earlier versions.
Roof plan view settings shows 1 story down.
Floor below (ground floor) has all its walls as "All Relevant Stories"
Graphic Override has a rule that says any 3D objects that has its home story on Ground Floor shows as dashed line.
2017-07-07 04:11 AM
2017-07-10 01:21 PM
