2020-11-26
		06:28 AM
		2023-05-24
		07:56 PM
			Rubia Torres
2020-11-26 07:04 AM
2020-11-26 07:14 AM
2020-11-26 07:20 AM
jake_h03 wrote:
The plot thickens!
The column I'm trying to cut through is a custom profile Ubeam. When I extend the beam to pass through both flanges, the intersection works and the column is cutaway where the beam passes through. But if I shorten the beam again to only pass through one flange, the intersection doesn't work. In neither instance is the beam passing through the column reference line.
Can anyone explain this sorcery?
2020-11-26 01:13 PM
2020-11-27 03:21 AM
2020-11-27 07:19 AM
2020-11-30 10:37 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
