‎2004-05-28
06:39 PM
‎2023-05-25
06:23 PM
Rubia Torres
‎2004-05-29 12:00 AM
Archibot wrote:This will provide all of the updates to 8.1 R2C, no matter what patch you are currently using...
It is unclear what version of the update i should downlowd from the table on the link you provided. help me out
‎2004-05-31 05:14 AM
‎2004-05-31 06:56 AM
Archibot wrote:Which library? Standard one or something else?
well i updated to ac v2 and nothing has changed.
‎2004-06-01 05:23 PM
Djordje wrote:It should be the standard library too. I have never changed it. and i just updated to the new library.Archibot wrote:Which library? Standard one or something else?
‎2004-06-01 10:43 PM
‎2004-06-02 01:23 AM
‎2004-06-02 01:35 AM
Ben wrote:YOU ARE THE MAN!!!! IT WORKED. I DONT KNOW HOW IT GOT CHANGED BUT THAT FIXED IT!!!!!
Check you display options. right click on plan/display options. Here in "doors and windows" you have the option to hide on plan
Hope this helps
‎2004-06-02 01:43 AM
‎2004-06-02 08:29 PM
Ben wrote:Lose the sugar ... double espresso is fine
Glad to help someone else out finally!!! Score is Ben - 1 Architalk - 1000
‎2004-06-02 09:45 PM
Archibot wrote:One more thing to add here. It's probably defined in one of your view sets. So if you select that view set again the same thing will happen. What you will need to do is to redefine you view set so the doors and windows remain visible on your paln.Ben wrote:YOU ARE THE MAN!!!! IT WORKED. I DONT KNOW HOW IT GOT CHANGED BUT THAT FIXED IT!!!!!
Hope this helps
YOU ARE MY NUMBER ONE!
THAKNS MAN
