‎2007-08-24 02:54 PM
‎2007-08-27 08:06 AM
Dwight wrote:
NOT AT ALL!
I made curved, non-vertical walls in AC 10 by magic-wanding arcs or splines using a very small magic wand segment length. This, with a custom profile and - uh, was it the wall tool or the beam tool????
Attached is a composition using the technique with some SEO fun - wall segment stands alone as an example.
Rod wrote:
Only solution!
‎2007-08-27 02:04 PM
Dwight wrote:One simple problem with your solution is with openings. and this object needs huge CPU-power.
NOT AT ALL!
‎2007-08-27 05:33 PM
