Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Is it possible to create Slanted Curved wall??
So... šŸ™‚
13 REPLIES 13
Dwight wrote:
NOT AT ALL!
I made curved, non-vertical walls in AC 10 by magic-wanding arcs or splines using a very small magic wand segment length. This, with a custom profile and - uh, was it the wall tool or the beam tool????
Attached is a composition using the technique with some SEO fun - wall segment stands alone as an example.
No, I need perfect curved wall but this is nice wall too
Rod wrote:
Only solution!
Like Dwight did, it's possible to merge simple walls into almost curved šŸ™‚ That's why I said it's "maybe the best solution"
Dwight wrote:
NOT AT ALL!
One simple problem with your solution is with openings. and this object needs huge CPU-power.
Djordje
Dwight,
Could you reduce the images a bit? Please?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dwight
Sure. But not much more than they do in Archicad 11.
Curves is curves.
Dwight Atkinson
