2013-04-26
03:45 PM
2023-05-26
02:23 PM
Rubia Torres
2013-04-26 08:47 PM
mr wrote:You are making a lot of assumptions here that you can't possibly know. It might be simple to implement but I can think of plenty of reasons why it might not. I also know that I have NO idea of what it would actually require. Why are you so sure of yourself?
Thanks for your reply!
To solve the problem it is a matter of one line! in Archicad´s programming code:
IF NOT SELECTED -> SHOW
as an alternative to the line now bringing us the mess to have to deselect from:
IF SELECTED -> SHOW
Just one line!
Hopefully there are some Archicad programmer trying to fix the missing line!
Hopefully there are a lot of users demanding this!
So let us demand this simple line in Archicad:
2013-04-26 08:58 PM
2013-04-26 09:19 PM
2013-04-26 09:25 PM
2013-04-26 09:28 PM
2013-04-26 09:47 PM
mr wrote:I have also used Revit for a long time and am not so much defending ArchiCAD as pointing out ways to accomplish what you want and why ArchiCAD's tools are superior to Revit's despite the latter having one specific function that ArchiCAD accomplishes by different means. As a rule I prefer not to use the hide function in Revit as it is much harder to track and control than using filters and such.
As I can understand both of you have used Archicad for a long time.
Perhaps - your feelings are: "It is my program" and you have to defend it.
But to defend something you have to make a retreat - understanding that the sun also has its shadows - to improve the program. It is about to listen to other users of the program.
As a user you have to trust the programmers. Hopefully some programmer listens to our discussion - one line of code - needed.
Hopefully I am not alone demanding that line of code to make Archicad so much better!
2013-04-26 10:06 PM
2013-04-26 10:39 PM
mr wrote:So start the topic in the wish list.
Archicad 16:
Right click and show selection in 3D
Archicad 17 will give us the alternatives?
Right click - show selection in 3D
and
Right click - don´t show selection in 3D
Just so simple. I believe I am not alone wanting the alternatives.
2013-04-27 02:04 AM
2013-04-27 07:08 AM
mr wrote:Select all - Shift-Click on the items you don't want to see ( that is to say de-select them ) - press F5. This will display everything you still have selected in 3D.
Now you have to select - marquee what you want to see in the 3D window.
I want to do the opposite - I want to select the objects I want to hide.
Is it possible to do that? Some hidden command to do that?
