2011-10-05 08:15 PM
2011-10-05 08:45 PM
2011-10-05 09:19 PM
ahmed_hassan wrote:If you mean to remove duplicate elements there is an add-on available from Grahisoft. Go to menu: Help > ArchiCAD Downloads
i was wondering if there is command overkill that delete the lines above each other, i will wait answer from other members because this command consider important to me.
2011-10-05 09:30 PM
2011-10-05 09:52 PM
2011-10-05 09:54 PM
ahmed_hassan wrote:I assume you are using DWG. I'm not sure if there is an easy solution for this. I believe ArchiCAD can smooth DWG on import but I don't know if this can be done going from ArchiCAD to AutoCAD.
Great, i see it called check duplicates tool.But this remind me by object circular when i made it in archicad and then export it to autocad it becomes like separate many lines any solution for this?
This happens usually with me in projects.
2011-10-05 11:26 PM
2011-10-05 11:54 PM
rob2218 wrote:check duplicates is one way
Not sure if my question was answered?
Attribute Manager...yes, I am aware of the Attribute Manager but.....where within the attribute manager do you "clean out" stuff you aren't using?
2011-10-06 09:23 PM
