ā2022-11-21 01:38 AM
Is there a way to select a Label and know what object it is associated with?
Solved! Go to Solution.
ā2022-11-21 01:43 AM
Yes.
Just hover your mouse over the label as if you are going to select it (but don't actually select it),
The label will highlight.
You will also see the associated element highlight as well
Yes.
ā2022-11-21 02:34 AM
You can also add more than one auto-text to the label, such as the Library Part Name (or other IDs) which you may want to show or confirm for a group of objects on plan vs schedule.
ā2022-11-21 03:32 AM
thank you so much. ^^
