Is there a way to select a Label and know what object it is associated with?
LeeJaeYoung
AC27 on window 11
Yes.
Just hover your mouse over the label as if you are going to select it (but don't actually select it),
The label will highlight.
You will also see the associated element highlight as well
Yes.
Marc H
You can also add more than one auto-text to the label, such as the Library Part Name (or other IDs) which you may want to show or confirm for a group of objects on plan vs schedule.
ā€œThe best thing about the future is that it comes one day at a time.ā€ - Abraham Lincoln
AC28 USA on 16ā€ 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
thank you so much. ^^
AC27 on window 11
