Is there a way to update a seved view?
I want to know if it's posible to update a saved view if the project gets modified or has some changes and instead of creating new views, I want to know if it's posible just to "updating" them.
I'm working in a big project and will be tedious to create all the new views.
What do you suggest?
Thanks
4 Replies 4
Eduardo Rolon
Yes views should update automatically unless you have "unlinked" them, that is one of the basic benefits of using AC.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks Eduardo,
One way of updating it:
1. Set the viewpoint to the state you want to save it (Layer Combination, Dimensions etc.)
2. In the View Map, select the View you want to update.
3. Click "Settings" in the View Map under the list of Views.
4. Click the "Get Current Window's Settings" button at the top of the Dialog.
The fields will be filled with the current settings.
5. Click OK to save the updated View.
how to unlink them? if i want to save different stages
