2009-12-1303:56 PM - last edited on 2023-05-2505:47 PM by Rubia Torres
2009-12-1303:56 PM
Hi guys,
While creating a slab with the magic wand method, the area below the boundary walls is ignored. If the wall has doors or openings of any kind in it, the lack of the slab below shows up as a void. How do I avoid this?
Besides it would be seen as a discontinuity in sections. So this is a legit problem.
Im forced to use the magic wand method in this case cause the boundary is not regular in form.
Try grabbing the edge of the slab after you have placed it and then pick 'offset edge' from your pet pallette then enter the value of your wall thickness into the tracker.
