Issues with modeling in 3d - height stretch - AC27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-11-09
05:17 AM
‎2024-02-06
12:26 AM
Hey all,
Having issues with using the 'stretch height' command in 3D. It seems to jam up the program, the only way to fix the issue is click off along the top bar of the window and then back into the working space.
Seems to be happing across the board with this command in 3d - not just isolated to cabinets.
the X marks where i need to click to get it back. This is the same across a team of 8.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-04-23 03:00 PM
Please solve this bug, its already really long time since we need this to be OK. We really dont need slow and memory heavy AI visualiser, but we need fast working software. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-07-26 10:25 AM
I have noticed same problem already in AC26. AC25 is last version without this problem..Object height could be stretched in earlier Archicad versions easily, but in the newer versions AC freezes and shows zero height. This happens even with the most simple block object as well as with objects in Graphisoft library. I notice that Graphisoft have added dynamic (red) hotspots to their objects, so I am guessing they are aware of the problem and have solved it that way. If it is not possible to fix the problem, please take the height stretch option away from the pet palette.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-07-26 10:54 AM
It definitely causes a long delay in 27 (seems like a freeze but it just very slow to respond).
I notice also in sections/elevations as well as 3D.
The moving hotspots do help.
The good thing is I just checked in 28 Tech Preview and it all seems good there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-29 11:34 AM
PLEASE REPAIR THIS ANNOYING ERROR, i really need to stretch objects in 3d and this is not working for a year.. where is the fix??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-29 11:53 AM
What I noticed is that when you selected a bunch of the same elements and you want to stretch the height it works like there's no issue but if it's a single element it goes hay wire.
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-29 12:03 PM
Ok, but we need solid solution, not some punk stuff.. 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-10-06 05:31 PM
It seems that in AC28 this problem is fixed, so it affected AC26 and AC27 versions only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-10-18 12:54 AM - last edited on ‎2024-10-18 02:15 AM by Barry Kelly
I was excited that this would be solved in version 28. But no. The same error continues. It only works by selecting another object. Oh yeah, it works without any problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-10-18 07:24 AM
I thought it was solved in 28 - IT WAS NOT!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-10-18 07:32 AM
Hi, please is there a possiblity to finally solve this bug?
when i want stretch the height of 3D object, Archicad freezes. The problem started in 27, It was unsolved for a year and in new version 28 - problem again. It is a high priortity error!
