ā2008-04-29
10:29 PM
ā2024-05-03
02:32 PM
Aruzhan Ilaikova
ā2008-04-29 10:39 PM
Boreskie, wrote:It sounds like you are referring to "Adjust" -- you must have the Wall tool active (to adjust wall elements) -- select object to adjust, command + click on the wall with which you want it to meet.
Virtual Tutor 10 shows a technique to cause 2 walls to join (select one wall, hold command key on Mac down, left click the other wall). I do not find it works in 11 - how do I get walls to join?
ā2008-04-30 03:35 PM
