2023-05-25
02:02 PM
2023-05-25
04:32 PM
Rubia Torres
Is there a way to keep Solid Element Operation Window open by default? Every file requires me to open it from fresh even though I use it everyday.
What is the reason for this? Am I doing something wrong?
Solved! Go to Solution.
2023-05-25 04:42 PM - edited 2023-05-25 04:44 PM
Hi @FCA,
You can set it in your work environment settings to appear in the toolbar. Easily you can open it while working:
Step 1 - Add the Solid Element Operations command to your toolbar
Step 2 - Just click on the SEO icon to open the dialog
Best,
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
2023-05-25 05:25 PM
Great, thanks so much!
2023-05-28 08:11 AM
Or you can assign a keyboard shortcut. I use Control O.
