Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Label Mesh Points for Topography
I am using a mesh to generate topography from a site survey by aligning the mesh points on the points from the surveyors data. Is it possible to label each mesh point with a spot elevation automatically??
This would be helpful both in modeling and documentation. During modeling, it would be very helpful to ensure that each point is the same as the survey rather than clicking on each point individually.
Thanks
2 REPLIES 2
Kyle,
not an automatic method but one that would help ensure you have entered the points correctly would be to place levels with 'gravitate to mesh' option over all points you wish to elevate before you elevate them then they will update as you elevate the mesh points
Regards,
Scott
David Maudlin
kyleboyd:
See this thread for an object that can read the xyz file and show this information: Making mesh from map and text values (imported from dwg).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
