jm23
convert CSV to .xyz or .txt file to create mesh from surveyor's data
Hello,
Looking to export the data points from the CSV file attached so i can drop in a .xyz or .txt file to archicad to create the mesh topography from surveyor data.
Is there an easy way of doing this?
4 Replies 4
Yves
Import the cvs into an excel spreadsheet with separator.
Delete first and last column
And save as text
I attach the converted file
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
CSumner
Hello,
Please can someone convert the csv file attached into a useable txt file for archicad?
Thank you in advance!
Emre Senoglu
I can convert it for you, but there seems to be missing data for some of the points. Do you have any idea why that might be? When I convert it to TXT and import into AC I get a generic error - presumably because of the missing data.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Nurbs
Hi, I've attached the txt file . I've had to remove some points with missing z-value as @Emre Senoglu mentioned.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
