2009-05-06
11:59 PM
2023-05-25
04:34 PM
Rubia Torres
2009-05-08 06:51 PM
You could try what we do.I think this may do the trick. I don't need to edit the location of the roads...just the contour. I'll give this a shot.
The roads and foot paths are slabs that are sited above the mesh.
we then to a 'plan' render in lightworks.
This gives you a jpg file of the roading layout.
Next, create a new material with the render image to drape over the mesh.
It doesn't look like a complicated site, except all polygontrees. Have you checked your hardware / software so you don't have something running in the background that slow down your computer?Also...I just recently put the trees back into the site. I had deleted all large objects but this did not solve the problem...so I put them back in.
when i applied an SOE on a mesh which had been also SEoperated then editing took forever.I think this is exactly what I'm experiencing!!!!
I copied the ground and applied a SEO. Seemed that the problem was not the polygons but applying sequential SEO on a mesh.
just keep it in mind
2009-05-09 02:43 PM
Designr wrote:Lindsay:
Does any one have a "simple" tree made? I tried to create one with a column and sphere and saved as an object and I kept getting GDL script errors. So I borrowed a tree from the archicad library deposit that was slightly smaller than the default AC12 trees.
2009-05-09 07:55 PM
2009-05-11 01:05 PM
Designr wrote:It is right there in the library - any AC deciduous tree with crown type elipsoid! There is also resolution parameter!
And a "simple' tree would be great!
