Layout Book with problems
i have a rare problem, (archicad 12), im creating a layout book, with 4 layouts, one master. I put the drawings with "save view and place in layout" and everything its ok. But when i want to made a change in the floor plan and the drawings make the actualization process.......the drawings dissapear!!!!....the frame its still there, but the drawing move far away (when i change the propertie to "fit frame to drawing" jump into another place), the drawings are in the origin, and it happens only in this file, always work fine, except in this case....can anyone help me????
1 REPLY 1
Does this help at all?
http://archicad-talk.graphisoft.com/viewtopic.php?p=173712#173712
