Layout book - Selections not working (gravity/magnet)
rob2218
in my layout settings (the sheets) I can no longer "select" for example the view map that is showing on the layouts.
I can select and use the selection fencing and crossing windows will in the actual view map but when I am in the layout book (sheets) I can no longer use the gravity tool (magnet) nor any of the selection fencing??? I can't believe it.
I've rebooted, started Archicad a few times and nothing......
I did install the Hotfix today and installed the IFC fix patch as well but it was working fine.
Did I do something I shouldn't have? did I accidently "click" on some damn button that I shouldn't have?....
HELP please!!!
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
rob2218
wow...if the "grid snap" icon is turned on in the layout books, you cannot use the "magnet/gravity" icon nor the selection fencing function....WTF? is this??
at least the problem was solved from another thread...but man..how freaky is this ???
Is this a bug with the fixes in hotfix or the IFC patches???
i>u
Edgewater, FL!
SOFTWARE VERSION:
__archiben
no - it's a scale issue. if your grid is set to 2000mm and your layout measures only 840x594mm you're not likely to be able to select it unless it crosses a grid line are you?
~/archiben
b e n f r o s t
