Got the file - thanks.
I am overlooking something that I can't put my finger on (it has been a long week!).
Your walls are there in elevation - you can select them.
However it seems they do not have any perimeter lines in 3D.
So you can see the surface but not the edges.
Your elevations are set not to show the surface colours, so you are not seeing anything at all.
If I copy your wall to my file, the perimeter lines are missing in 3D.
If I copy one of my walls to your file it is fine and shows in elevation.
So the thing I can't put my finger on is why your walls have no perimeter lines.
It is something so obvious I am just overlooking it, or it is indeed a glitch.
Does anybody else have any ideas?
