Length of lines
Ok, so this is probably the most stupid question ever..
I just started using Archicad 11 instead of archicad 9, and I cant figure out how to see the length of the line as I'm drawing?! I know you can measure it afterwards, but this takes a long time and is unaccurate.
In archicad 9 you could press ctrl-r and type in the length that you wanted. How can I do that now??
Thank you!
14 REPLIES 14
You need to turn on your "Tracker"
you can turn it on through your Work Environment.
And then you will see your info. To type in the length, you can use "r" or "d", but you dont NEED to type anything fist, just your dimension.
Eduardo Rolon
I don't know if the shortcut is enabled by default but you can type "M" for measure.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Jesikuh123 is right... turn on your Tracker. There is an icon for it in the main tool palette along the top of the screen.
Thank you so much guys! I was going crazy!:-) I really appreciate it!
Djordje
Do yourself a favour and turn the Coordinate and Control boxes on. Tracker is a cosmetic gimmick, because Revit has it. I vote for functionality.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thomas Holm
Djordje, I'm an old dog too and I always keep both Coordinates and Cotnrol box visible. But I still like the Tracker so much I want it on all the time!
How could you work without the Coordinates anyway? I use the Tracker too, but it cannot replace Coordinates! Not until great improvements are made in it!
And why do you need the Measure tool?!? There are faster and easier ways to measure a distance and they have been there for years!
Measure tool is an illustration that Tracker does not do the job!
Rob
When I have tried the tracker for the first time there wasn't way back. I have actually forgotten there is something like coordinates box. It is soooo yesterday...
::rk
Eduardo Rolon
Student: How do I know the distance from point A to point B?
Professor: Press "M" for measure and click the 2 points
VS
Professor: Make sure that you have the coordinates palette open and move the origin by pressing Command+Option+Shift to the start point, then move the mouse to the other point and read the distance. Or select the line tool click on the first point and move to the second read the distance and press "Esc" to cancel the line.
The problem is the "years" part in the comment, we already "Know" but there is nothing wrong to let GS make it easier for new users. I agree that the tracker is not perfect and I have the coordinates on and use it all the time but it can be argued that it has become a "power user" tool. IMO it is easier to press "M" and 2 clicks and sometimes we "older" users have to unlearn stuff. As a bonus measure in spanish starts with the same letter so it is easier to remember.
AC29 US/INT -> AC08
another Moderator
