2012-05-0210:07 AM - last edited on 2023-05-2304:36 PM by Rubia Torres
2012-05-0210:07 AM
Hi.
I have a problem to use Level Dimension.
I want to show the story level by using Level Dimension.
I don't want to use Label or Object.
How can i do it? Is it impossible?
Place a Slab the top level of which is the same as the Level of the Story.
Activate Gravitate to Slab. Then place a Level Dimension with you cursor over the Slab. You can then even put that Slab o a hidden Layer if you otherwise don't need it.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
I think the only way to do that is to select the Text portion of the Level Dimension and switch from Measured Value to Custom Text and type the value you want displayed.
